Aktuella MSW 60667 uppdateringar maerklin.de
Just börjat testa den nya enheten.... då man inte längre har mobil app utan kör CS3 web interface som inte lirar till 100%
4.0.0.1 16.03.2023
First release version
4.0.0.2 12.09.2023 **
Troubleshooting the release version
Core
The UID is now calculated correctly (avoiding collisions on CAN bus and decision main and secondary unit).
Manuell nedladdning: msw_firmware.bin
MSW uppdateringar från 230316 och framåt
Svensk tågsamling sedan tidigt 80-tal med favoritloket Ra
Re: MSW uppdateringar 4.15.0.10 15.04.2024
4.15.0.10 First April update 2024
Published on: April 15, 2024 at 09:00 AM
Release version bug fixes and improvements
NEWS
When starting, it will now be displayed which network the MSW is trying to connect to.
There is a new menu item with which you can choose whether the locomotive icon is displayed or not.
There is a new menu item to delete locomotives.
WEBAPP
The list of error codes in the WebApp has been moved from Info to Firmware Update.
IMPROVEMENTS
Handling of the central connection revised.
Handling of the WLAN connection revised.
Handling of the encoder and dynamics revised.
Timeout increase for CV programming to 12 seconds.
DCC-CV programming via PoM is now permitted for all CVs.
OS
Search for control centers expanded to include an additional procedure (from CS3 2.5.2).
WLAN
Handling of WPA3 completely revised.
WLAN
Search for WiFi networks revised.
BUG FIXES
WEB
Fixed a bug that prevented long passwords with special characters from being entered.
Fixed a bug that prevented updates on Mac OS with Safari.
Error when entering password via rotary encoder corrected.
Error when entering password via keyboard corrected.
Fixed a bug that put the MSW in an invalid state if the connection to the control center failed after the WLAN connection was established.
When starting without a known network, the network list is now displayed correctly.
Added timing out monitoring when reading the MFX block list.
Password is now reset correctly when deleting the WLAN.
Fixed mfx locomotive detection bug.
OS
Connection attempts with the IP 0.0.0.0 are now correctly acknowledged negatively.
OS
Fixed sporadic stack overflow when logging in to WiFi.
NEWS
WEBAPP
IMPROVEMENTS
OS
WLAN
WLAN
BUG FIXES
WEB
OS
OS
